Production/Dissipation Ratio
Prev Previous Post   Next Post Next
Old   July 25, 2001, 13:45
Default Production/Dissipation Ratio
John
Hi everybody. Does anybody know what the ratio of production to dissipation looks like for adverse pressure gradient flows in the outer layer of a turbulent boundary layer? In a zero pressure gradient flow this asymptotes to 1, but for adverse pressure gradient the value is bigger. Any references? How does k-epsilon model predicted? Over or underpredictcs? I have some results which predict a higher ratio than standart k-epsilon. I need to verify this. Thanks in advance. John
[ICEM] Error in Prism Ratio Computed singer1812 ANSYS Meshing & Geometry 0 September 22, 2011 16:29
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
