ROTOR 37 TRANSONIC FAN
Old   August 3, 2001, 03:53
Default ROTOR 37 TRANSONIC FAN
Joerg Weidenfeller
In order to validate a NS Code I am looking for the well known test case of NASA Rotor 37 Transonic Fan. Results using this test case were presented at the ASME Gas Turbine Institute meeting in June 1994 at The Hague, The Netherlands and ERCOFTAC meetings. There are many researchers which cite this test case but I have not found the original data. Does anyone know a possibility for accessing the data (via WWW)?
Thanks in advance
Joerg
Old   August 6, 2001, 13:34
Default Re: ROTOR 37 TRANSONIC FAN
Dan Hinch
I believe Rotor 37 data is part of the ERCOFTAC database.
Old   August 8, 2001, 03:36
Joerg Weidenfeller
Thank you very much for your help. You are right: Rotor 37 is cited in ERCOFTAC database. But unfortunately the data are not available.
Joerg
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 11 February 17, 2021 11:30
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Proper BCs for internal fan serezhkin CFX 3 July 28, 2010 10:04
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 19:37
