August 7, 2001, 08:37 |
thermoacoustics
hello, can you please give some information regarding thermoacoustics. by rajani
August 7, 2001, 18:18 |
Re: thermoacoustics
Thermoacoustics theories are applied for axial and centrifugal turbomachinery. Specially noise propagation is an important parameter when dealing with aeroengines because of noise regulations near airports and towns. Because of that many efforts have been made in order to reduce the intensity level produced by engines in operation. There is a description of thermoacoustic theories applied to axial compressors and fan in: N. A. Cumpsty. "Compressor Aerodynamics". Longman. 1989
August 8, 2001, 03:56 |
Re: thermoacoustics
thanks for your mail. but thermoacoustics are also applied for other applications. i am looking for a general introduction. basically i would like to use acoustics in combustion problems. if you have any reference please tell me.
August 9, 2001, 19:32 |
Re: thermoacoustics
Your best bet would be to search Journals especially those relating to turbomachinery and combustion and search for combustion instability. you can search for recent papers in this area in the proceedings of the ASME 2001 Turbo Expo at the ASME's website.
August 10, 2001, 02:49 |
Re: thermoacoustics
Thank you.
August 13, 2001, 06:53 |
Re: thermoacoustics
http://www.acs.psu.edu/THERMO/thermoacoustics.html
http://www.arl.psu.edu/areas/acsrefrige/acsrefrige.html A promising cooling technology. You going to investigate using CFD? Fred. |
August 14, 2001, 03:56 |
Re: thermoacoustics
thank you very much. i am itersted in application of accoustics in turbulence and combustion problems. if you have any ideas regarding application of acostics in the above areas please tell me. by rajani
August 16, 2001, 12:22 |
Re: thermoacoustics
There are some papers regarding thermoacoustics in the ASME TurboExpo 2000. If you are interested in any of them, I can provide you some
August 17, 2001, 04:25 |
Re: thermoacoustics
#9 |
Hi, thank you very much for your mail. Can you please send me the papers to the following mail.
<akula@hrz2.hrz.tu-darmstadt.de> thank you very much for your help. by rajani |
thermoacoustics. | prasat | Main CFD Forum | 2 | November 29, 2002 03:32 |
