Preconditioner
Old   August 29, 2001, 03:12
Default Preconditioner
Nailya
Hi, I'm Nailya. I solve Navier-Stokes equations in implicit way using finite difference method on unstructured meshes, TVD method, Newton's method. The obtained linearized system I try to solve using GMRES method. The problem is that the matrix of system is very ill-conditioned. I need in a good preconditioner. How can I obtain it?
Old   August 31, 2001, 15:47
Default Re: Preconditioner
David Sun
You can try to find some packages such as QMRPACK, SPARKSKIT from netlib and there are some preconditioning GMRES built in...
Old   August 31, 2001, 17:58
Chuck Leakeas
Nailya, Why is your system of equations so ill-conditioned? Make sure you assemble your matrix correctly. You can start trying to precondition your system of equations using a Jacobi Preconditioner.
Chuck
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Accessing preconditioner members chegdan OpenFOAM 0 April 28, 2010 12:29
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 01:18
Informations about LU-SGS preconditioner Renato N. Elias Main CFD Forum 0 September 9, 2005 11:06
Preconditioner for BiCSTAB Márcio Ricardo Main CFD Forum 1 October 12, 2004 07:10
