September 27, 2001, 13:33 |
higher gauss Quadrature rule for triangles
Dear friends I am doing certain error analysis in FEA. In order to eliminate the Numerical Integration error, I want to use higher gauss quadrature rule for triangles. I have found 10x10 rule for Quads but i could not find it for triangles. Presently I am using 12 point integration for triangles. if any body have used it or know some literature, then i will need his help
I appreciate your help |
September 27, 2001, 13:39 |
Re: higher gauss Quadrature rule for triangles
The easiest way is to consider a triangle as a degenerated quadrangle (when two of the vertices collapse into one). Note that higher-order quadratures are readily available for quads.
Problem in fvschemes divSchemes cannot use Gauss linearUpwind | nico765 | OpenFOAM Bugs | 30 | August 9, 2018 07:39 |
please help me which solver is better for my application | Ger_US | OpenFOAM | 8 | January 8, 2013 12:29 |
Gauss Quadrature points | dhruv | OpenFOAM | 4 | September 26, 2011 04:59 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
Quadrature Rule for Triangles | Khurram | Main CFD Forum | 3 | August 28, 2002 19:15 |
