NACA Airfoils
Old   December 4, 2001, 09:45
Default NACA Airfoils
Igor
Need NACA airfoil generation code - preferable source so I can incorporate into my research studies. Anybody know free tools avaialble?
Old   December 4, 2001, 11:13
Default Re: NACA Airfoils
Fernando Sanz
Have a look at:
http://www.pagendarm.de/trapp/progra...les/NACA4.html
Old   December 4, 2001, 11:23
Andrew Parker
http://raphael.mit.edu/xfoil/
This address well let you download a program called Xfoil it is a viscous boundary layer code, but has the ability to output any NACA 4-digit airfoil with up to 280 points specifying the curvature. You can also modify the camber and scale the airfoil before you do this, I find it very good although not designed for this purpose.
Go to this site and download the file, if you need help extracting the airfoil polars I will be happy to tell you the steps.
All the best
Andy
Old   December 5, 2001, 01:35
FYW
http://amber.aae.uiuc.edu/~m-selig/ads/naca980820.bas
Coordinates of NACA airfoils Mohammad Main CFD Forum 9 April 19, 2012 03:47
multiple airfoils at once, are they affected? kdrbrk FLUENT 0 October 18, 2010 05:31
Symmetric NACA Airfoil Lift and Drag Data jrider22 Main CFD Forum 3 April 15, 2010 04:59
MOdelling a 3-D structure of a fan blade using NACA airfoils ashu.feb28 Main CFD Forum 0 February 2, 2010 10:19
Drag coefficient of NACA airfoils L3munoz Main CFD Forum 3 April 23, 2009 11:52
