Can someone help me calc. flow through this????
Old   January 15, 2002, 20:21
Default Can someone help me calc. flow through this????
Todd
I've got a 4" duct with a 1" sharp edge metering orifice. Inlet pressure is 18"H2O and outlet is vented to atmospheric pressure. Please help!
If this isn't possible how about: 18"h2o vacuum inlet, and a 4"h2o pressure drop across orifice. thanks, Todd
Old   January 15, 2002, 20:25
Default Re: Can someone help me calc. flow through this???
Todd
Oh yeah, It's using clean air and I need cfm output. Thanks again. Todd
Old   January 16, 2002, 18:06
Niall
Todd,
Go to the following website
www.lmnoeng.com
Go to the section on orifice calculations.
All the formulae necessary for calculating the flow through an orifice are given, so you should be able to do the calculation yourself.
The flow units will not be in cfm, but you should be able to convert to cfm easily.
Note: The site offers you the option of inputting your data into a spreadsheet, but this costs $$$. There is no need as all the equations are specified at the end of the page. There are also plenty of references for flow through orifices.
Niall
Old   January 17, 2002, 08:35
Todd
Thanks Niall! I've been millin over the equation for a couple days. I can't quite figure how to get the velocity so I can input it into the equation. Was hopin someone here could spell it out for me as to what units of measure they'd be. I'll keep tryin an maybe buy one of the basics books. Thanks again. Anyone else willin to give it a shot? Todd
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
Viewing the mass flow rate of particles using function calc. saran CFX 0 March 22, 2009 12:07
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
