Can someone help me calc. flow through this???? |
January 15, 2002, 20:21 |
I've got a 4" duct with a 1" sharp edge metering orifice. Inlet pressure is 18"H2O and outlet is vented to atmospheric pressure. Please help!
If this isn't possible how about: 18"h2o vacuum inlet, and a 4"h2o pressure drop across orifice. thanks, Todd |
January 15, 2002, 20:25 |
Re: Can someone help me calc. flow through this???
Oh yeah, It's using clean air and I need cfm output. Thanks again. Todd
January 16, 2002, 18:06 |
Todd,
Go to the following website www.lmnoeng.com Go to the section on orifice calculations. All the formulae necessary for calculating the flow through an orifice are given, so you should be able to do the calculation yourself. The flow units will not be in cfm, but you should be able to convert to cfm easily. Note: The site offers you the option of inputting your data into a spreadsheet, but this costs $$$. There is no need as all the equations are specified at the end of the page. There are also plenty of references for flow through orifices. Niall |
January 17, 2002, 08:35 |
Thanks Niall! I've been millin over the equation for a couple days. I can't quite figure how to get the velocity so I can input it into the equation. Was hopin someone here could spell it out for me as to what units of measure they'd be. I'll keep tryin an maybe buy one of the basics books. Thanks again. Anyone else willin to give it a shot? Todd
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
Viewing the mass flow rate of particles using function calc. | saran | CFX | 0 | March 22, 2009 12:07 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
