PML approximation
Old   January 22, 2002, 17:00
Default PML approximation
vineet kshirsagar
hi,
When we apply PML boundary there a a different set of equations along the PML and the main computational domain (and also different variables). Can any one please suggest to me how should i approximate the values required for the computations of these different variables and equations, along the PML main domain interaction. eg . if i am calculating at i'th grid point (in the main domain) and (i+1)'th gridpoint is in PML domain then how do i approximate the other variables(in the PML domain) for time marchiing for the grid point i, and vice -versa.
the PML equations considered by me are for linearised euler equations and i an using paper by Mr Fang Q Hu " on absorbing boundary conditions for linearised euler equations by a perfectly matched layer" as reference.
thanx in advance
vineet
undergraduate student
IIT bombay
India
Old   January 25, 2002, 21:43
Default Re: PML approximation
paul
In Fang's paper, he splitted a variable into two variables. eg. u=u1+u2. But all the derivatives with respect to x and y are for the unsplitted variables. You don't need to use the splitted variables in the main domain. If you need the unsplitted variable u in the PML domain, you only need to add u1 and u2 together.
Hope it is helpful to you!
Old   January 27, 2002, 00:59
vineet kshirsagar
thanx, but i did not get ur point that i won't need the splitted variables in the main domain.... i understand that main domain doesnot have the splitted variables, but at the boundary ot the PML and the main domain to apply any kind of numerical scheme, i should require its adjecent values, i want to know what should i do in case of such a case, i have done the same as you mentioned when i required "u" in the PML domain, i just added the "u1" and "u2" but whaat should i do if i waht the reverse....
awaiting reply. thanx vineet
Old   January 27, 2002, 02:54
paul
I think you may solve the eight splitted equations with the absorbing coefficients \sigma equal to 0 in the main domain.
InterFoam with boussinesq approximation sinusmontis OpenFOAM Running, Solving & CFD 2 October 25, 2020 12:21
finite difference approximation Mucx Main CFD Forum 1 May 26, 2011 07:46
Question on boussinesq approximation panos_metal FLUENT 1 January 11, 2010 11:18
Mac Cormack scheme and use of PML boundary conditi vineet kshirsagar Main CFD Forum 1 January 13, 2002 01:46
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 09:24
