Heat Transfer Correlation
Old   February 5, 2002, 13:01
Default Heat Transfer Correlation
Peter
Hi to all,
Does anybody knows a correlation for the Nusselt number in annular or circular rotating ducts?
Peter
Old   February 19, 2002, 10:08
Default Re: Heat Transfer Correlation
gita
Hi Peter,
Nusselt number is a function of Reynolds,Prandtl,Brinkman nos,& the geometric factor L/D. In the absence of viscous dissipation Brinkman no can be neglected. This is true for constant wall temperature. When the temperature differences are large,then you need to include mu_b/mu_0 in the correlation relation where mu_b is the bulk viscosity and mu_0 is the viscosity at the temperaure of the solid surface. Nu=Nu(Re,Pr,L/D,(mu_b)/(mu_0)). This is for forced convection. If density varies significantly,then some free convection will occur and Grashof no must be taken into account. Try to get hold of some good references to check these things. Hope you have got some idea. If you have access to the library that's the best place to dig out. Regards gita
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
