January 13, 1999, 19:41 |
difference between false and true transient
In case of unsteady calculations one often encounters two terms namely : False transient, True transient. As I understand it, a false transient solution does not give the true transient behaviour but gives the correct final steady solution. Are there any other differences between a false transient and true transient solution?
Thanks |
January 21, 1999, 13:45 |
Re: difference between false and true transient
There are only two types of equations1) steady-state equations, and (2) unsteady-state equations. The unsteady-state equations describe the transient behavior of the problem. Sometimes, instead of using the steady-state equations to obtain the steady-state solutions, people have tried to use the unsteady-state equations to obtain the steady-state solution. But, you never know whether this approach will lead you to the steady-state solution or not. And you also have to run the code for a long time in search of the steady-state solution. In the hope to reduce the computing time, some people try to set the time step to be a function of the grid point ( or cell ) in such a way that the time step for that cell can be increased thus the computing time reduced ( if the steady-state solution can be found in this way).
problem with Transient Thermal Ansys | simox 2 | ANSYS | 0 | January 11, 2011 14:49 |
Compiling OpenFOAM 1.7.1 on Ubuntu 10.10 | samiam1000 | OpenFOAM Installation | 4 | November 24, 2010 08:00 |
False Transient | tommy | CFX | 1 | February 9, 2006 16:47 |
Expert Parameter for compressible transient | ioannis | CFX | 0 | November 2, 2005 19:28 |
