Finite Volume Example
Old   April 3, 2002, 08:15
Default Finite Volume Example
Matt Kellerman
Hi, I am a relative newcomer to the field of CFD and have been following "An introduction to Computational fluid dynamics - The finite volume method" by Versteeg and Malalasekara. What I am interested in doing, is producing some code which incorporates the following:
- Overview: Solves for Pressure and velocity using SIMPLE algorithm using a staggered grid in two dimensions.
- Boundary Conditions: Known velocity at inlet and constant pressure outlet.
- Differencing Scheme: Hybrid differencing
- Flow type: laminar, Non-Compressible.
I have several questions before I know enough to be able to use the finite volume method to build the above model - Mainly around the implementation of boundary conditions, Source terms and also solving for pressure correction. What would be ideal is if anyone could point me in the direction of a worked example similar to the above scenario that I could follow which would most likely answer all of my questions.
If not, I'll post some specific questions that I have.
I only have limited access to University library resources (through a friend), so a URL, or feel free to e-mail me anything that you think may be of use to me.
Many thanks for your time and help,
Matt Kellerman.
Old   April 10, 2002, 11:42
Default Re: Finite Volume Example
Yong
There is a quite good book talking about FVM,
Computational Methods for Fluid Dynamics by Joel H. Ferziger, et al
and also you can get the sample code ( such as using FVM and SIMPLE scheme to solve 2D flow) from ftp://ftp.springer.de/pub/technik/peric/
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
