VELOCITY
Old   May 1, 2002, 13:59
Default VELOCITY
WILLIAM DIETER
I am having trouble figuring out the final velocity of air applied to a six foot tube with a .5" diameter from an unlimted 3000psi source... can anyone help?
Respectfully, William Dieter
Old   May 2, 2002, 02:34
Default Re: VELOCITY
John Dreese
With that pressure ratio (3000psi to Ambient), you'll have choked flow through the pipe. The maximum speed will be Mach 1. Assuming isentropic flow from standard temperature to Mach 1, your static temp will drop to about 433 degrees Rankine. That makes the exit speed of sound 1020 feet/second or 696 mph. So, that's about the speed of your exiting flow. Increasing your inlet pressure will just increase the mass flow (density). Increasing inlet temperature will increase your speed. My calcs are a little rusty but I think that's right.
That calculation doesn't take into account pressure losses through the pipe or what happens as the jet expands into an open space.
John Dreese
Maker of DesignFOIL
www.dreesecode.com
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
