Open Source Code for Lattice Boltzmann Method
Like Tree4Likes
Closed Thread
Old   October 5, 2007, 20:48
Default Open Source Code for Lattice Boltzmann Method
Halim
Can anyone show me the internet web site where I could download an Open Source Code for the Lattice Boltzmann Method? I just start to learn the Lattice Boltzmann Method and I need a code for beginnners. Plaese help me if you can.
Old   October 6, 2007, 18:23
Default Re: Open Source Code for Lattice Boltzmann Method
emca
on which subject work you ? this is a link for sample codes http://www.physics.ndsu.nodak.edu/wagner/LB.html
Old   October 7, 2007, 19:39
Halim
Thank you very much. I am working on fluid flow and heat transfer.
Old   June 18, 2009, 17:56
Default Lbm
khaleel al khasawneh
kh16867 is on a distinguished road
I am trying to simulate the flow over flat plate using LBM , did somebody have something similar to this case ?
thanks
kh16867 is offline
Old   January 24, 2012, 03:18
Default LBM couette flow
mark
bagogan is on a distinguished road
I just start to learn the Lattice Boltzmann Method and I need a code for couette flow. Can anyone help me in this subject? . Please help me if you can.
bagogan is offline
Old   January 24, 2012, 06:02
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
You can chech out www.palabos.org. It offers open sourced LB code.
Pei-ying
phsieh2005 is offline
Old   January 24, 2012, 07:08
mark
Thank's for your answer but I can't find any example with couette flow
bagogan is offline
Old   May 2, 2012, 17:44
Yong Wang
ywang is on a distinguished road
If you are using palabos, find the example of poiseuille flow, and just change the boundary condition. Hope it's helpful.
ywang is offline
Old   February 1, 2014, 05:38
Roya.TR
Roya.TR is on a distinguished road
I have an example code for coutte flow. If you want, please give me your email adress that I send it for you.
Roya.TR is offline
Old   February 3, 2014, 06:26
Default Lbm
Tom-Robin Teschner
t.teschner is on a distinguished road
I have developed a 2D lattice Boltzman solver for my Master Thesis, it has a CGNS mesh reading and so far supports the single, two and multiple relaxation time scheme for the collision operator, the D2Q9 speed model and Zou/He boundary conditions (and the simplified bounce back as well). It comes with a text based user interface including some sort of tutorial mode to help the user to get familiar with the solver or it can be launched from input files. I have tested and validated it against standard test cases (channel, lid driven cavity, backward facing step, sudden expansion, cylinder) and works well with any 2D structured mesh.
If you are interested in it, please message me. I can also give you a copy of my thesis which describes the LBM in its essence and also covers heat transfer + it has a very simple, striped down version of a lid driven cavity to help understand the LBM proceedure.
swati, oluwaseyi and Ami_s like this.
t.teschner is offline
Old   February 27, 2014, 20:00
Default Request
  #11
JK1
Julie Kirk
JK1 is on a distinguished road
Hi t.teschner
Is it possible to send me the 2D code and your thesis?
Regards
JK1
JK1 is offline
Old   November 13, 2014, 09:24
yagizb
yagizb is on a distinguished road
Hi t.teschner
Is it possible to send me the 2D code and your thesis also?
Regards
Bedri.
yagizb@gmail.com
yagizb is offline
Old   February 13, 2015, 03:08
Default LBM code
  #13
grissa kods
grissa is on a distinguished road
Please could you sent it for me
grissa is offline
Old   June 16, 2015, 05:26
Mathias J Krause
mathiasj is on a distinguished road
Have a look at the open source OpenLB project webpage www.openlb.net . That is the LBM I recomment!
mathiasj is offline
Old   August 19, 2015, 11:09
majid mohammadifar
majid123 is on a distinguished road
hi t.teschner
can you send for me a copy ?
majid123 is offline
Old   August 19, 2015, 12:51
Pei-Ying Hsieh
Could you please send me a copy of your code and thesis?
Thanks!
Phsieh2005@yahoo.com
Old   November 12, 2015, 17:46
Yana H is on a distinguished road
Hello t.teschner
I will be very grateful if you can send me the 2D code and your thesis?
ymarusa@gmail.com
Thank you
Yana H is offline
Old   November 27, 2015, 10:44
Daniel Camacho
dgcamacho is on a distinguished road
Could you please send me the 2D code and your thesis? My email address is
dgcamacho@gmail.com
Thank you
dgcamacho is offline
Old   November 29, 2015, 08:44
C. Ziyad
phy4me is on a distinguished road
hi t.teschner
phy4me@gmail.com
phy4me is offline
Old   November 30, 2015, 04:58
grissa kods
I ROYA could you please send me the code my email: grissakods@gmail.com
Thank you alot
grissa is offline
Closed Thread
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
2D Field Panel Method Source Code Shukla Main CFD Forum 3 January 20, 2011 12:51
open source code of k-e turbulence model. karuna Main CFD Forum 1 June 4, 2006 10:09
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 03:40
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
