July 11, 2002, 15:08 |
CVD reactors
Does anyone know why if I change the inlet concentration of a precursor gas the deposition rate remains the same?
July 15, 2002, 11:33 |
Re: CVD reactors
What does CVD represent?
August 16, 2002, 07:05 |
Re: CVD reactors
Hallo,
it depends from case to case. Usually you have a limitation, coming from the deposition mechanism. It means that during deposition, you have a step during which, the precursor must get to the surface of your wafer. This can happen through absorbtion and so on. The limiting step is the amount of free places on your surface. As far as these places are limited you don't have any posibility to increase your deposition rate by increasing the concentration of your precursor. If the mechanism is known, try to influence some steps, like desorbtion, reaktion rate (through pressure and temperature variation). hope it helps. Jannis |
Experts in Simulating BUbble Column Reactors | aliyah | Main CFD Forum | 7 | June 19, 2012 02:38 |
[GAMBIT] modelling of Trickle-Bed Reactors for Wastewater Treatment | balu@gold6 | ANSYS Meshing & Geometry | 0 | November 22, 2010 02:09 |
Question about CVD model | mahe | Phoenics | 1 | September 16, 2008 12:19 |
cvd can't work | mahe | Phoenics | 0 | February 25, 2008 22:01 |
CFD on LDPE reactors | Luis | Main CFD Forum | 1 | March 18, 2005 03:38 |
