CFD ACE help
Old   August 13, 2002, 22:00
Default CFD ACE help
Chris J
I am currently attempting to model the scavenging process for a small two stroke engine using CFD ACE. The model will need to be transient and the mesh will have to deform to simulate the motion of the piston.
The model will be made up of 3 blocks; the cylinder; the transfer ports; and the exhaust port. I hope to feed pressure data for the transfer port and exhaust port for each time step.
What is the best way to approach this problem? The tutorials dont seem to address mesh deformation and transient problems.
Old   August 14, 2002, 10:12
Default Re: CFD ACE help
Richard Thoms
Hello Christopher,
We actually have a rough-draft of the grid generation portion of this problem in tutorial format, you can request it via the normal support channels (support@cfdrc.com)
You will need to make the grid system such that the piston can slide relative to the ports. This will require the use of the arbitrary interface feature allow flow communication between the cylinder grid and the port grids.
If you would like more detailed information please email to support@cfdrc.com and we'll take care of you.
Regards, Richard Thoms
about VOF. Fluent or CFD ACE? Jiyeon FLUENT 5 January 17, 2012 04:37
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 04:48
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
