Pressure boundary & buoyancy
Old   October 22, 2002, 05:29
Default Pressure boundary & buoyancy
Bouke
Dear all,
I have a question concerning incompressible flow with buoyancy.
If I have a vertical outlet plane (pressure boundary) in a case where gravity is included in the equations (e.g., to model natural convection), is it OK to set a constant relative pressure (e.g., 0 Pa) along the outlet or should I correct for the pressure gradient (rho*g*h)?
In my code, the pressure boundary is set by fixing the value of the pressure to a given value for each cell of the outlet. I have seen in commercial codes that you can specify an "average" pressure at an outlet; does anybody know how this is implemented?
Thanks,
Bouke
Old   October 22, 2002, 06:08
Default Re: Pressure boundary & buoyancy
D.M. Lipinski
Bourke,
Define your pressure, p, in the Navier-Stokes equations, as the static pressure minus hydrostatic pressure. I.e. use the difference, density minus the reference density in the buoyant term. Then you can use the boundary condition p=0 on the outlet.
regards
DML
Old   October 22, 2002, 11:37
Bouke
OK!
I thought that would be difficult to implement but the opposite is true & it works like a charm.
Thanks!
Pressure boundary condition C-H Kuo Main CFD Forum 18 September 16, 2016 03:19
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 21:18
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
