November 6, 2002, 13:28 |
Eddy Dissipation Model
I am using the eddy dissipation model and have a question about the constants A(4) and B(0.5). What effect will changing either of these constants have on the reaction?
November 7, 2002, 04:50 |
Re: Eddy Dissipation Model
The eddy dissipation model calculates the reaction rate as: Rf = -rho*epsilon/k*A*min[mf, mo/so, B*mp/sp] where mf - fuel concentration, mo - oxidant conc., mp - product conc., so = no*Mo/nf*Mf and sp = np*Mp/nf*Mf Constant A goes directly into the reaction rate. Constant B is supposed to have an influence on the temperature dependeny of the reaction (mp is linked to the temperature). Lowering B will make the reaction rate more dependent on the product concentration, while increasing it will make the reaction dependent on the fuel and oxidant concentrations. You will probably have to play around with those two to get anything meaningful out of your calculations. Good luck! Regards, Volker |
November 7, 2002, 07:19 |
Thanks for clearing that up. I understand what's going on now.
Eddy Dissipation Model | Enots | CFX | 11 | August 12, 2011 04:11 |
EDDY DISSIPATION MODEL | PID | CFX | 0 | July 22, 2008 18:52 |
PrePDF or Eddy Dissipation | Mark | FLUENT | 5 | March 7, 2003 12:08 |
temperature too high in eddy dissipation | Peter Lemtis | FLUENT | 3 | November 24, 2002 00:45 |
EDDY BREAK UP MODEL | GACEM hatem | Phoenics | 0 | August 22, 2000 11:06 |
