Shock Ways
Old   October 27, 2002, 22:57
Default Shock Ways
saba
Hi, I want to know about shock ways why its generates and why its generates only in supersonic flows. bye
Old   November 5, 2002, 09:21
Default Re: Shock Ways
M. Akram
Solution of flow problems based on invicid theory breakdown at certain level. The discontinuties called Shock waves are accepted as jump discontinuties to save the solution. This happens when the true physics i.e., viscosity & thermal conductivity are ignored in modeling the fluid.
Old   November 5, 2002, 23:05
saba
My question is that why this discontineuties generate
Old   November 6, 2002, 06:09
Tom
The reason shock waves are generated is simply that in a hyperbolic system information is propagated along the so-called characteristic directions and when two members of the same characteristic family intersect the solution becomes multivalued; i.e. for the same instant in time and position in space there are two different values for the density,velocity, etc. In physical space the multivaluedness is removed by replacing it with a surface of discontinuity - the shock wave.
See the books
Linear and nonlinear waves by G.B. Whitham
High speed flow by C. J. Chapman
Supersonic flow and shock waves by Courant and Friedrichs
Tom.
Old   November 6, 2002, 22:41
saba
Thanks, I need this one
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
Shock Fitting Craig FLUENT 1 April 24, 2008 17:06
Will compression waves overtake a moving shock? GRA Main CFD Forum 2 October 19, 2006 00:24
Shock Ways saba FLUENT 2 October 31, 2002 01:33
Normal shock waves Fernando Velasco Main CFD Forum 1 April 6, 2000 14:10
