Start up Errors
Old   November 10, 2002, 10:06
Default Start up Errors
numethods
Hi, can anyone explain to me what do we mean by START-UP ERRORS in numerical solution (methods). any ref. around in this area...
Many thanks
Old   November 12, 2002, 10:49
Default Re: Start up Errors
Pete
You have to provide some initial condition for your problem. The difference between this initial guess and the final solution is the "start-up error" you refer to.
For example, one may initialize the flowfield around a body with freestream conditions. This doesn't represent the final flowfield, and as the solution converges, this error is reduced.
Generally, the closer the initialization is to the actual solution, the smaller the start-up error, and the faster the problem will converge.
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
