For turbulent boundary layer
Old   January 2, 2003, 14:43
Default For turbulent boundary layer
Orion
Since a even order central differential scheme has a huge numerical dissipation to the calculation of turbulence boundary layer, it is very difficult to hold the U_tau and turbulent statistical qualities. Structures are decay very fast in my LES simulations, dynamic modeling + LUSGS scheme used on that.
My question is that,
Does anyone encounter it before? Do you have some suggestions to the numerical dissipation?
Old   January 2, 2003, 22:45
Default Re: For turbulent boundary layer
Linfeng BI
As far as I know, 2nd order central difference scheme can work fairly well in LES if the desired order of the statistical quantities is not too high ( say 2nd order).
Maybe your mesh is not fine enough, or try employing a wall model in your simulation.
regards
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 14:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 03:40
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
boundary layer thickness 98.4F Main CFD Forum 1 December 29, 2000 07:23
