solving non-newtonian fluid
Old   April 1, 2003, 20:34
Default solving non-newtonian fluid
tao
HI
I want to solve the flow with non-newtonian fluid in a tube using numerical method. The carrau model is used as a constitute equation. mu=viscosity gamma=shear rate
(mu-mu_inf)/(mu_0 - mu_inf) = (1 + (lamuda*gamma)^2)^((n-1)/2)
The governing eq.
0=-dp/dz + 1/r * d(mu*r*dw/dr)/dr
I would like to solve this, but have no idea. For newtonian fluid, it's so simple to analyze this. The constitue eq. and governing eq. are coupled. How can I deal with this problem using numerical approach(tips or algorithm)? If anyone know how to solve this or some open sources availalbe on site or at ftp, please let me know. I would much appreciate your help.
Thanks in advance. Peace in God.
Old   April 2, 2003, 13:37
Default Re: solving non-newtonian fluid
xueying
Your problem equations are: (1)constitutive equation; (2)momentum conservation equation; (3)mass conservation equation.
Solve these three equations by Newton method since they are non-linear. Your unknowns are pressure, velocity and viscosity. You don't need boundary codnition for your constitutive equation since it's a linear algebraic equation.
From mathematical view, this way should work. I don't know if it's practical or not in your case.
Old   April 2, 2003, 20:01
tao
I just want to know the solving procedure in numerical approach. Normally, I prefer interative method(SOR), not newton method.
Old   April 3, 2003, 04:48
Tom
Why not just solve it by iteration/quadrature:
(1) Guess w (w_g) and calculate mu
(2) update w (w_*) by integrating the momentum equation (it's a simple quadrature).
(3) obtain a new guess for w from w = (1-q)w_* + q*w_g
(4) repeat from 1 until converged.
In 3 q is a relaxation parameter used to stop the iteration oscillating (which it will do if q=1 ).
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
