How to implement a fan curve in CFD
Old   April 5, 2003, 04:06
Default How to implement a fan curve in CFD
Steve
I am trying to model a fan/blower in my code. Could anyone provide me some guidance on how to incorporate a fan curve in a FEM code? Many Thanks!
Steve
Old   April 9, 2003, 09:43
Default Re: How to implement a fan curve in CFD
BeachComber
Your question is quite vague. Would you please clarify a bit further?
Old   April 12, 2003, 14:40
Steve
I was trying to create a model to simulate fan effects in flow fields for electronic cooling applications. Here the fan curve(pressure difference vs flow rate across the fan) is known.
Recently I have figured out this can be done by simply adding the pressure drop (given in the fan curve) into N-S equations as a force term.
What's your opinion? Thanks!
Steve
Old   April 14, 2003, 02:37
Tom
Try to locate the PhD thesis of Dr M van Staden. He did a PhD specifically on this topic.
You can email him at: Martin.vanstaden@pbmr.co.za
His PhD is about implementing fan curves for axial fans into a CFD code using momentum source terms. Great reading!
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 19:37
Fan slection--ystsem pressure curve MHK FLUENT 0 September 12, 2007 13:46
about fan curve stanta Siemens 1 June 1, 2005 10:09
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
