Time splitting in DNS
Old   May 12, 2003, 19:52
Default Time splitting in DNS
fan
Orszag + Patterson ["Num. Sim. of 3D Homogeneous Isotropic Turbulence", Phys. Rev. Lett. (1972)] solve homogeneous isotropic turbulence via a spectral method.
They combine the solution of the Poisson equation with the Navier-Stokes equation so that the solution automatically satisfies continuity. Thus, they don't use a time-splitting algorithm.
Yet, spectral methods for inhomogeneous flows have to use a time splitting (or coupled) method.
I'm assuming that they are able to enforce continuity analytically thru their equation (2) because the flow is homogenous-isotropic. However, I don't completely understand why this can't be done for inhomogeneous flows. Is it because of the "non-periodic" boundary conditions that a time splitting method has to be used for non-homogeneous flows.
Thanks.
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
time dependent source using DEFINE_SOURCE T81 Fluent UDF and Scheme Programming 5 February 28, 2011 17:23
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
VOF özgür FLUENT 8 January 6, 2004 08:23
