steady/unsteady combustion???
Old   June 13, 2003, 08:32
Default steady/unsteady combustion???
john
Hi all,
Could someone explain to me what steady and unsteady combustion is?
I mean when should the simulation be solved for steay state conditions and when should it be solved for unsteady conditions????
Cheers
John
Old   June 13, 2003, 09:04
Default Re: steady/unsteady combustion???
prasat
I will be happy to help you out.
As in a laminar flow the fluid motion reaches a steady state.Therofre it is enough to simulation the Navier stokes equation steady term(without the unsteady or transient term). But in case of turbulence we nedd to solve the transient term also. You can apply the similar arguments in case of combustion. prasat
Old   June 13, 2003, 09:55
john
Hi prasat,
Thank you for your reply.
Does that mean, that if I want to simulate a furnace i have to do an unsteady simulation which causes large computation time, or is there an assumption I can use to simulate the furnace combustion with steady state formulation.
cheers,
John.
Old   June 13, 2003, 10:40
prasat
What type flow is it turbulent or laminar one. I guess that it will be turbulent only. so that means for simulation you have to take the unsteady term also. prasat
Old   June 13, 2003, 11:32
john
I don't know if you use fluent but in their turbulent combustion tutorial the solver is steady state.
If the flow is turbulent shouldn't the solver be unsteady?
This is the information I really want because if i know why they were able to solve in steady state maybe I too can, saving me a lot of time.
Old   June 13, 2003, 12:18
gorka
If you use RANS (Reynolds Averaged Navier Stokes) approach for modelling turbulence it's not true that you must perform unsteady simulation. In fact, you should solve the unsteady problem only when the unsteadiness is caused by flow features (vortex sheding, time varying BC etc.)
Gorka
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
steady/unsteady combustion??? John FLUENT 1 June 15, 2003 07:25
