G-Invariance---->urgent help please
Old   June 9, 2003, 09:37
Default G-Invariance---->urgent help please
xiang
what is the meaning of Galilei Inveriance ?
please help to explain it....
Old   June 9, 2003, 10:19
Default Re: G-Invariance---->urgent help please
Tom
It's an expression of Newtons first law; i.e. the equivalence of inertial frames. This basically means that the equations of motion must be the same in all inertial frames.
If we have two inertial frames one at rest x and another moving at constant velocity c with respect to x, X say, then
X = x - ct
The velocity v measured in frame x is then V=v-c in frame X. The equations of motion in frame X is obtained from that in frame x by replacing x,v with X,V. This is Galilean invariance.
It's VERY basic physics.
Old   June 9, 2003, 10:39
xiang
the problem it's VERY BasiC PhysicS
thanks Tom
Old   June 9, 2003, 12:29
A.S.
Can you suggest some literature or book specially for Navier-Stoke equation.
Regards
Old   June 10, 2003, 04:31
Tom
It depends on your background and what you want to know. (I'm a mathematician and so the following are rather biased):
A good basic text is
Elementary fluid dynamics bt David Acheson (Oxford University Press)
An introduction to fluid dynamics by Paterson (Cambridge University Press)
is also a reasonable book. If you have a more physics based background then
An introduction to fluid dynamis by G.K. Batchelor (Cambridge University Press)
is probably a good place to start.
Hydrodynamics by Lamb (Cambridge/Dover?) is also worth a look (although it's pre-tensor analysis) as are
Theoretical hydrodynamics and Theoretical aerodynamics
both by Milne-Thompson and published by Dover.
For more rigorous discussion try
Applied analysis of the Navier-Stokes equations by Doering and Gibbon (Cambridge Unversity Press)
or, if you can find it,
The mathematical theory of incompressible viscous flow by O.A. Ladyzhenskaya
There's also a two volume set by Pierre-Louis Lions (Oxford University Press) but I haven't seen these (yet) and various books by Roger Temam.
Invariance of relative total temperature jpo FLUENT 0 June 9, 2011 15:39
Gallalian Invariance Wayne Main CFD Forum 12 June 20, 2005 04:23
Gallalian Invariance -------Again David Liu Main CFD Forum 2 June 20, 2005 01:01
Riemann Invariance Javier Main CFD Forum 2 March 25, 1999 08:02
Gausian Invariance Tom Main CFD Forum 1 August 12, 1998 15:04
