laminar shock
Old   June 18, 2003, 04:22
Default laminar shock
P.Fonteijn
Hi all,
I have a low density gas (1 mbar), in which a shock is present. Based on the Reynolds number (100), the flow is laminar. My question is if it is physically correct to assume that the flow around a shock is laminar. Isn't it always turbulent......
Kind Regards, Pascale.
Old   June 18, 2003, 06:00
Default Re: laminar shock
Tom
At such a low Reynolds number do you actually have a shock?
Strictly speaking a shock can only form in a inviscid fluid (where it is termed a weak solution). At high Reynolds number the discontinuity is smoothed out through a viscous transition layer which results a smooth (or strong) solution. As the Reynolds number decreases the thickness of the transition layer grows and eventually becomes a meaningless concept. This is similar to the concept of a boundary layer - it's impossible to talk about boundary layers at low Reynolds numbers.
At a Reynolds number of 100 the flow will be laminar,
Tom.
Old   June 18, 2003, 10:15
P.Fonteijn
Hi Tom,
The software I use, calculates a speed of sound based as a function of the molecular mass (100-300 kg/kmol). Then, when velocity becomes larger than this speed of sound, Mach exceeds 1,2,3 or whatsoever, and will fall down at a certain position. All simulations I have seen so far are not really influenced by the density.
Pascale
Old   June 19, 2003, 00:52
Michael Elford
Hi Pascale,
I have run inviscid and laminar simulations of shock diffraction over objects such as cylinders and half diamonds at ambient pressures of 10Pa. I have found the results to match to shock tunnel experiments extremley well using a laminar assumption.
Old   June 19, 2003, 16:55
P.Fonteijn
Hi Michael,
Thank you for responding. Do you have any references in open literature, or can you recommend open literature in general regarding this subject?
Pascale
Old   June 19, 2003, 20:51
Michael Elford
Hi Pascale,
I have not yet published any papers as I am concentrating on completing my thesis. However, if you want to see papers on shock diffraction try this journal:
"Shock Waves" - springer verlag
Also, I think there are some simulations on this web page which might be of interest to you:
http://www.mech.uq.edu.au/staff/jacobs/cfcfd/index.html
Thread Tools
Trackbacks are On
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 6 January 26, 2013 10:11
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 1 July 7, 2009 13:44
Shock Fitting Craig FLUENT 1 April 24, 2008 17:06
Will compression waves overtake a moving shock? GRA Main CFD Forum 2 October 19, 2006 00:24
Normal shock waves Fernando Velasco Main CFD Forum 1 April 6, 2000 14:10
