eddy viscosity distributions in the wake?
Old   June 25, 2003, 22:22
Default eddy viscosity distributions in the wake?
zqnwpu
Is there a gap for eddy viscosity distribution in the wake ? when i use structure c grids,there is.but my classimate using unstructured grids got a no-gap result,why?
Old   June 26, 2003, 09:38
Default Re: eddy viscosity distributions in the wake?
kei-tee
wake of C grids is singular line. Usually, we use wake line BC as averaged value of nearest grid points. ie. suppose wake line are j=1,jmax,
q(1)=q(jmax)=0.5*(q(2)+q(jmax-1))
best regards
kei-tee
Old   June 27, 2003, 03:53
zqnwpu
Thank you very much. I just do as you said .but there is a gap in the wake ,I don't know whether it is right.
Old   June 29, 2003, 04:12
kei-tee
What kind of Turbulence model do you use? Some model needs special treatment for wake BC.
Old   July 1, 2003, 00:26
zqnwpu
i use k-epsilon,k-omeg & other use spalart.
Old   July 1, 2003, 09:47
kei-tee
S-A needs wall distance. In wake region, you should take the value as large value (ex. 1.0E6).
I don't know for k-eps & k-omega.
As long as you impose averaged value on Q vector & eddy viscosity in wake region, there is not a gap, I think.
Boussinesq eddy viscosity assumption siw Main CFD Forum 2 February 17, 2011 12:30
Eddy Viscosity Transport Model Jade M Main CFD Forum 0 April 21, 2010 14:17
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES Marvin Main CFD Forum 6 December 4, 2009 11:08
Question about eddy viscosity ratio limit Piti CFX 2 January 17, 2008 16:49
eddy viscosity Mike CFX 1 April 4, 2006 13:12
