Structure vs unstructured meshes
Old   July 18, 2003, 05:28
Default Structure vs unstructured meshes
Des Aubery
Hi everyone,
I am busy trying to evaluate the impact of using a 'structured' vs an 'unstructured' mesh, in highly-complex flow domains.
The assumptions used for the heat-tranfer coefficient at the walls of internal shapes seem to run into some accuracy problems for 'unstructured' meshes, when compared to 'structured' meshes.
I would really appreciate advice here.
My models typically contain around 494+ included internal shapes.
I was hoping to use the CFD package to provide me the surface heat-transfer coefficients, without having to calculate bulk heat-transfer coefficients.
Thanks for your advice.
Regards,
Des Aubery... (adTherm Technology - Virtual Thermal Engineering)
Old   July 21, 2003, 21:02
Default Re: Structure vs unstructured meshes
Jim Park
I think there was a pretty extensive debate of the structured - un-structured question recently here.
Try searching this forum, then the CFD-ONLINE archives. If your answer isn't there, you should at least have an idea of what to expect in the way of answers.
Old   July 25, 2003, 23:11
Des Aubery
Hi Jim,
Thanks for your reply.
I had tried a search, but ended up with a lot of spurious data. Let me try again...
Best regards,
Des Aubery...
Velocity/pressure/Temperature blow-up while dealing with unstructured meshes psosnows OpenFOAM Bugs 4 October 19, 2011 15:48
Merge 2 unstructured meshes vinc ANSYS Meshing & Geometry 0 May 19, 2011 16:14
unstructured or structure mesh? fadhil FLUENT 5 July 14, 2008 03:12
structured vs unstructured hexahedral meshes Usman FLUENT 0 January 19, 2008 04:20
Higher Order FV Schemes for unstructured meshes Apurva Shukla Main CFD Forum 4 December 15, 2000 09:17
