Explicit calculation issue
Old   April 19, 2009, 19:34
Unhappy Explicit calculation issue
lost.identity is on a distinguished road
I'm trying to run an unsteady calculation using the explicit method using an inhouse CFD code. The problem is when I use explicit my time step size is very small (of the order of -12). So it is taking a very long to to achieve the required simulation time.
I can't seem to find a bad cell which might give such a small time step and I want to use Tecplot to show me the local timestep (assuming CFL=1) for all the grid points, i.e. I want to read in a steady flow result of the same geometry in Tecplot and then calculate the the timestep size using the flow speed, mesh size and CFL=1.
Is it possible to do this in Tecplot? Or does anyone know of a better method to achieve this?
Thanks in advance.
I.
lost.identity is offline   Reply With Quote
explicit, tecplot, unsteady
Mixing elbow case water heat transfer calculation buoyantFoam benyamin1 OpenFOAM Running, Solving & CFD 0 January 14, 2006 09:25
Warning 097- AB Siemens 6 November 15, 2004 04:41
Rotation flow calculation Christian Main CFD Forum 5 April 3, 2003 13:19
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
Channel LES and explicit filtering Luca Liberti Main CFD Forum 0 January 17, 1999 10:07
