HP Turbine stage BC's
Old   July 28, 2003, 13:17
Default HP Turbine stage BC's
Puneet
I have a 3d stator-rotor HPT stage grid. I am not sure whether I am using the correct BC's to study the interaction. Rotor blade : Wall Stator Blade: Wall Rotor Hub: Wall Stator Hub: Wall Rotor Inlet : Pressure Inlet Rotor Outlet: Pressure Outlet Stator Inlet: Pressure Inlet Stator Outlet: Pressure Outlet
Mixing Plane: Stator Outlet- Rotor Inlet
Here is what I am not sure about
Pitchwise boundary of Stator Grid - I am using periodic BC will it be rotational periodic or translational periodic
Pitchwise boundary of Rotor grid: Will it be rotational or translational periodic
Mid Spanwise cutting plane parallel to hub : I am using symmetry but I have a 3d curved profile. Think this is not the one I should be using.
Any help?
Regards
Two stage axial turbine in CFX sherifkadry CFX 16 June 8, 2020 07:58
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
Turbine stage mixing plane calculation Knut FLUENT 0 December 4, 2007 12:46
two stage steam turbine sebastian FLUENT 6 June 7, 2006 02:15
Want Stator-Rotor Turbine Stage Grid Puneet Main CFD Forum 0 July 11, 2003 16:47
