cfd beginner
Old   August 1, 2003, 00:37
Default cfd beginner
Rupesh
hello everybody,
i am an emerging researcher in the field of cfd.i would like to know about the basic knowledge that is required to get started.
Old   August 1, 2003, 03:05
Default Re: cfd beginner
jon
I started off with J.D. Anderson's "Computational Fluid Dynamics: The Basics with Applications". It's more inclined towards aerodynamics, and assumes no prior knowledge.
Old   August 1, 2003, 03:25
Mark
An introduction to computational fluid dynamics: the finite volume method by versteeg & malalasekera is very good too.
You should try to get your hands on the following paper too - "The best practice guidelines for CFD - A European initiative on quality and trust" by Wintergerste, Torsten; Casey, Michael; Hutton, Anthony G. 2002. published in ASME, Pressure Vessels and Piping Division.
Old   August 1, 2003, 07:16
Tom
Don't bother with the staggered orthogonal grid approach of Versteeg, it will only confuse you and is largely redundent technology. Instead, concentrate on face based collocated unstructured algorithms instead. Also, concentrate on the Finite Volume method. It is simply the most widely used approach today. Anderson largely consentrates on Finite Difference approach. Rather refer to Peric's Computational Methods for fluid dynamics. Boy am I going to get shots on these comments!! My appologies folks. Comments are welcome though!
Old   August 1, 2003, 08:15
david
I agree with Tom, but to read more is no harm. I've read both the books anyway.
Old   August 1, 2003, 13:02
centaur_ks
i would suggest read through the basics first. Dont jump into which method is better and which is not. Once you understand basics then you would understand why some methods are better then others. Read through Anderson's book, Malashekhara's book.. even patankar.
J-
CFD Code + partner required + beginner amol palekar Main CFD Forum 1 July 18, 2004 15:32
Beginner - Has Phoenics CFD software for mixing? mixerer Phoenics 2 July 10, 2002 10:54
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
