Question regarding Fluent's Turbulent Pipe Flow Problem
Old   May 15, 2009, 03:59
Default Question regarding Fluent's Turbulent Pipe Flow Problem
clueless is on a distinguished road
I had used FLUENT to resolve the developing flow in a pipe for a pipe Reynolds number of 10,000 on the following meshes: 100x5, 100x20 with uniform spacing in the radial direction.
How do i compare the exit value with the expected value for fully developed flow (e.g., 1/7th profile or your fine mesh results)???
[IMG]file:///X:/Fluent/pipe2/ps1_files/ps1equation.JPG[/IMG]
This should be either less than 4 (so that you resolve down into the viscous sublayer) or greater than 30 (where wall functions can accurately compensate for the poorly resolved viscous sublayer).
However I got a value between 8 and 12 for the 100x20 mesh.
How do i calculate the value of y1+ for each mesh??And how does it help explain the trends in the agreement that i observe??
clueless is offline   Reply With Quote
LES turbulent pipe flow panara OpenFOAM Running, Solving & CFD 68 January 26, 2023 11:34
simple pipe flow question arkur Main CFD Forum 0 June 29, 2008 18:07
turbulent flow in cavity problem using k-w model khairy Main CFD Forum 3 February 27, 2005 12:12
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
