COG(Coke Oven Gas) Combustion Problem in "W" Type Radiant Tube |
May 20, 2009, 23:55 |
COG(Coke Oven Gas) Combustion Problem in "W" Type Radiant Tube (3D)
Kang Jung Shin
Hi, Everyone
I'm trying to solve heat problem of "W" type radiant tube <Grid Design> -------------------- <= Fuel & Air Supplying Line ( -------------- ) -------------- ( -------------------- => Exhaust Gas Out When setting up CFD-ACE Model, #1. Chemical Reaction : CH4+2O2 -> CO2 + 2H2O "For Whole area of tube" -> Is It Right? #2. And When I do set up CFD-ACE Model like #1, In the 1st straight line(the most upper line), There is no CH4 mass fraction (=0) at all!! Why this happens? Did I do something wrong? Last edited by sdlafkj; May 21, 2009 at 00:28. |
May 21, 2009, 02:22 |
Kang Jung Shin
Hi, All. I got a clue~ Sorry to produce garbage..
February 19, 2011, 01:54 |
Coke Oven Gas combustion in W radiant tube
I am trying to model a W radiant tube for burning COG( containing mostly H2 and CH4). can u give me a basic idea for modeling in CFD. The flow of air and gas are co-axial. 1) can I model it in 2D, or 3D is necessary? 2) which reaction chemistry can be used. I want to use CH4 and H2 combustion chemistry. I want to model it using ANSYS-FLUENT |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Combustion Problem | Arnab | Siemens | 2 | April 29, 2009 08:13 |
Sod shock tube problem with real gas effects | ganesh | Main CFD Forum | 0 | October 17, 2006 01:22 |
