Setting up gas turbine blade geometry for meshing
Old   June 1, 2009, 16:28
Default Setting up gas turbine blade geometry for meshing
Sherif Kadry
sherifkadry is on a distinguished road
I have a question, I've been tasked to create a mesh that models a 3 stage gas turbine. The turbine has a series of 3-D blades for both stator and rotor stages. Is there a way I can use a 3D cad model of the turbine and create the flow channels for the blades versus using turbogrid or gturbo in gambit. Moreover, the design has a series of seals at hub and tip locations that will probably require tet meshing can anyone recommend a procedure to extract the needed geometry from a CAD model into either ICEMCFD or Gambit.
Thanks
sherifkadry is offline   Reply With Quote
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 01:04
internal cooling of gas turbine blade vinay FLUENT 0 October 20, 2008 15:20
Basic Turbine Blade Geometry Nathan Durley-Boot FLUENT 0 February 20, 2007 07:21
FEA of gas turbine blade and disc sureee Main CFD Forum 3 March 15, 2006 04:59
Warning 097- AB Siemens 6 November 15, 2004 04:41
