CHT in gas turbine, solid domain
Old   June 9, 2009, 05:18
Default CHT in gas turbine, solid domain
Alder
Alexandre is on a distinguished road
Hi everyone,
Doing some conjugate heat transfer simulation for a gas turbine blade, do you need prism layers in the solid domain to capture the convection due to the fluid? how fine should be the grid inside of the solid domain near the wall?
Thank you.
Alexandre is offline   Reply With Quote
Old   June 9, 2009, 07:51
SKK
SKK is on a distinguished road
You need prism layers when there is an interface between solid and fluid. This is to capture the effect of viscosity slowing down the fluid velocity to zero (boundary layer) as it approaches the solid surface.
Inside the solid region you do not need prism layer. The mesh there should be enough to capture the temperature gradient from one surface to the other.
SKK is offline   Reply With Quote
Decending Temperature to Solid Domain (CHT). sandeep_tu CFX 1 May 12, 2009 18:54
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
