Two phase Flow instability
Old   September 7, 2003, 16:41
Default Two phase Flow instability
shaoping
Hi, I am trying to simulate two phase flow instability. The original CFD solver is tested okey for single phase flow, and I got a two layer couette flow simulated right, the upper layer is gas, the lower is water,they are immiscible. Now I try to give a initial disturbance to excite the instability, but the disturbance will disappear which is not right. the code solve two phase coupled. Do I need to put a bondary condition of Balance of normal stress across the interface? Can anybody here give me some suggestion? you help will be greatly appreciated Shaoping
Old   September 8, 2003, 13:25
Default Re: Two phase Flow instability
Ali
In the absence of mass transfer, the gas and liquid phases should be explicitly coupled at the interface by continuity of velocities and shear stresses. For more info about interfacial jump conditions see:
Delhaye, J.M., Jump conditions and entropy sources in two-phase systems: Local instant formulation, Int. J. of Multiphase Flow, Vol. 1, p. 395, 1974.
twoPhaseEulerFoam: turbulence on produces instability of drag phase florian_krause OpenFOAM 1 October 11, 2013 09:02
behavior of two phase flow in a pipe Sonia84 FLUENT 5 September 17, 2013 16:31
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 02:57
More Probs - Gas-Solid 2 Phase flow Paresh Jain CFX 4 March 27, 2004 17:10
