oscillating valve flow
Old   September 10, 2003, 09:21
Default oscillating valve flow
Matthias Finke
Hi everybody,
does anybody has experience with modelling transient valve flow at steady state boundary conditions.
I have read a report about the simulation of a counterbalance valve where a jet flipping (a phenomena like vortex shedding behind a cylinder) occurs and was identified as the cause of high frequency (5 kHz), pure tone sound.
With the informations from the report i scanned the geometry of the model (2d axisymm) and set up a simulation with a finte element comercial code, but in my simulation there is no transient behaviour of the flow.
Does anybody done something similar or knows something about transient valve flow at steady state boundary conditions ?
I would be grateful for any help and suggestions
Old   September 10, 2003, 09:46
Default Re: oscillating valve flow
Jim Park
Can't comment on your valve problem as I have no experience.
The loss of transient behavior in a simulation (such as shedding, flapping, etc) can occur when the mesh resolution is inadequate. The numerical dissipation is so large that the simulation is run at an effective Reynolds number much lower than what is intended. Don't know if this is your problem or not - have you tried resolving your mesh and rerunning the problem?
Old   September 10, 2003, 13:59
Aaron
it might also be worth checking to see if your finite element program does any sort of stabilization for flow programs, e.g. SUPG, GLS, etc... Under the right conditions such procedures can help prevent of the numerical diffusion that can occur with larger grid sizes.
Aaron
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[ICEM] Blocking topology for pipe flow with a butterfly valve siw ANSYS Meshing & Geometry 13 November 27, 2012 12:07
oscillating flow bb FLUENT 2 February 22, 2006 01:24
Oscillating flow in pipe Alberto Schroth FLUENT 2 January 21, 2000 09:59
CFD Application in hydraulics valve flow Roger Yang Main CFD Forum 11 February 11, 1999 16:53
