K-omega for flow in branches?
Old   July 6, 2009, 14:25
Default K-omega for flow in branches?
afm
cfdlover is on a distinguished road
hello;
i'm trying to find the best turbulence model to be used for flow in branches and manifolds. using some data i found that standars and SST K-OMEGA is the best. is this ok? as i understand, k-w is only used for heat transfer applications. So, is it ok to use it for flow in branches?
thank you
cfdlover is offline   Reply With Quote
Old   July 6, 2009, 21:35
N/A
harishg is on a distinguished road
There is nothing like a best RANS model for a particular problem. Some models perform better than the other. Regarding k-omega model, it has been applied for a wide range of flows. You can choose either the SST model or the most recent k-omega model of Wilcox for your application. Also integrate through the viscous layer with damping if you might encounter flow separation.
harishg is offline   Reply With Quote
Specific Dissipation Rate (Omega) Lourival FLUENT 2 July 25, 2010 08:59
Definition of omega jpo FLUENT 4 April 7, 2009 15:06
Values of k and omega at the wall oldah FLUENT 2 February 22, 2008 03:08
Airfoil with k Omega hoochie OpenFOAM Running, Solving & CFD 0 July 3, 2007 08:10
Defining deformable mesh UDF to set omega Chris FLUENT 0 August 30, 2006 16:01
