October 2, 2003, 06:14 |
Help modelling 2 phase flows
I am currently working on a 2 phase model using water and air. Has anyone successfully modelled a partially submerged object using Fluent as the solutions we are getting are failing. The water and air are being treated as seperate inflows with separate velocities and they are imiscible. I would be very grateful for any help!! M Fortey
October 2, 2003, 08:59 |
Re: Help modelling 2 phase flows
Hi; I have tried to model the flow field arround ski of an aircraft by Fluent5.2.3. The results are very dependent to the numerical grid. The grid orthogonality is very important. With the triangular unstructure mesh, I got very bad results. Because the 3d nature of the flow, only with a 3d simulation I got approximatly good results with Fluent5.2.3. I am reported that very better results provided by using Fluent6. regards.
two phase modelling in bubble column | srikkanth | FLUENT | 1 | March 27, 2017 09:21 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Wall shear stress in two phase flows | idrama | FLUENT | 0 | September 17, 2011 13:56 |
two phase modelling: exhaust and air | Paweł | FLUENT | 0 | September 6, 2006 11:43 |
2 Phase Modelling | Kevan Moodley | Main CFD Forum | 1 | July 2, 1999 10:35 |
