July 30, 2009, 06:37 |
Comsol question
Rep Power: 17 |
I used Comsol to solve a PDE problem. I know that the solution is stored in the object fem.sol.u and the unstructured mesh points are stored in fem.mesh.p. If we assume fem.sol.u is a matrix of M*N (M is the number of spatial mesh points, and N is that for the time steps), then the fem.mesh.p should also have the dimension of M. Unfortunately, the mapping between index of p and u is not specified. Could anyone tell me how to do? Thanks. Windson |
July 30, 2009, 10:19 |
Rep Power: 17 |
You may never find how to do the mapping. One possible solution to your problem is to check if Comsol can export the solution in a different format, i.e., CGNS
July 30, 2009, 10:36 |
Rep Power: 17 |
Thank you for answering me. Could tell me explicitly about CGNS?
Actually, I don't understand why in using femtime as a solver the fem.sol object doesn't contain a list of mesh points, which correspond to the u value list. This will make life much easier ... |
July 31, 2009, 04:45 |
Rep Power: 17 |
You could search for CGNS on google. I do not know much about comsol, and I might not be able to assist you. I know that Ansys can export the results in this CGNS format. I thought that maybe comsol can do the same, or maybe comsol can export them in another but user-friendly format.
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
COMSOL: boundary conditions using sampled vectors | flying dutch | COMSOL | 0 | April 29, 2009 12:54 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
