July 31, 2009, 09:03 |
courant number
Salman
Rep Power: 16 |
Hi all,
I am running a pressure based steady state simulation in Fluent. I could not find a way to check the courant number. Is it not available with steady state calculations? looking for your expertise, please!!! Thanks Salman |
August 3, 2009, 08:19 |
Wiebe Zoon
Rep Power: 17 |
Hi Salman,
You can display the Courant number in a field by going to display->sweep surface->properties of contours->contours of :select velocity->second pull-down menu: select cell courant numper (at the bottom) Kind regards, Wiebe Zoon |
August 3, 2009, 09:08 |
Salman
Rep Power: 16 |
hi,
Thanks for the reply. I have checked the path you advised, but this is the "Cell Reynolds Number" at the bottom and not the cell courant number. I have no idea whether they are the same things or not? Regards Salman |
August 3, 2009, 09:17 |
Wiebe Zoon
Rep Power: 17 |
No, this is not the same. (With me, the Courant number is below the Reynolds number). Are you running a transient simulation or a steady state one? (The Courant number only has a meaning in a transient simulation.) Regards, Wiebe. |
August 3, 2009, 14:38 |
Salman
Rep Power: 16 |
hi,
Thats what I have asked in the main topic. ) Its a steady state simulation. So it means that courant number is not available for steady state!!! Thank you very much. Regards, Salman |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
