courant number
Old   July 31, 2009, 09:03
Default courant number
Salman
Salman is on a distinguished road
Hi all,
I am running a pressure based steady state simulation in Fluent. I could not find a way to check the courant number. Is it not available with steady state calculations? looking for your expertise, please!!!
Thanks
Salman
Salman is offline   Reply With Quote
Old   August 3, 2009, 08:19
Wiebe Zoon
wiebe is on a distinguished road
Hi Salman,
You can display the Courant number in a field by going to display->sweep surface->properties of contours->contours of :select velocity->second pull-down menu: select cell courant numper (at the bottom)
Kind regards,
Wiebe Zoon
wiebe is offline   Reply With Quote
Old   August 3, 2009, 09:08
Salman
hi,
Thanks for the reply. I have checked the path you advised, but this is the "Cell Reynolds Number" at the bottom and not the cell courant number. I have no idea whether they are the same things or not?
Regards
Salman
Old   August 3, 2009, 09:17
Wiebe Zoon
No, this is not the same. (With me, the Courant number is below the Reynolds number). Are you running a transient simulation or a steady state one? (The Courant number only has a meaning in a transient simulation.)
Regards,
Wiebe.
Old   August 3, 2009, 14:38
Salman
hi,
Thats what I have asked in the main topic. )
Its a steady state simulation. So it means that courant number is not available for steady state!!!
Thank you very much.
Regards,
Salman
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
