heat trasnfer coefficient
Old   July 21, 2009, 09:01
Default heat trasnfer coefficient
nic
nicolas
nic is on a distinguished road
Hi everyone,
I am looking for any equation to calculate the heat transfer coefficient for the following case:
A cuvette made of metal and inside there is water (in a batch system). Outside of the cuvette there is water flowing for heating the inside content of the cuvette.
I think this case corresponde to forced convection, and for this case I could use the Nusselt number for external flows:
Nu = 0,66*Re^(1/2) * Pr^(1/3).
then: heat transfer coefficient = Nu*k / L
But I don't know what equivalent length (L) I shoul use for it. The corresponing one to where the external fluid is moving or the cuvette wall thickness?
And also for calculating the Reynolds number, I don't know either, since inside the cuvette the water is not moving.
Thank you very much!.
nic
nic is offline   Reply With Quote
Old   July 21, 2009, 09:49
Andrew
mettler is on a distinguished road
you might want to look into flow over a cylinder. You might be able to find a lot of the answers there.
mettler is offline   Reply With Quote
Old   July 21, 2009, 22:53
Ahmed
Ahmed is on a distinguished road
Originally Posted by nic View Post
Hi everyone,
nic
finding a convection correlation is not difficult, for example, look this link (the internet is full of such pages) http://www.cheresources.com/convection.shtml#annular
It seems to me the geometry is confusing you, attach a picture, may be we could help
Good luck
Ahmed is offline   Reply With Quote
Old   August 19, 2009, 22:07
Default Convection Heat Transfer
rodrigo
augusto_bassan is on a distinguished road
hi someone have or know where I can found the solution manual of book Convection Heat Transfer, third edition of author Adrian Bejan, because I need very much in my pos- graduate , thanks.
my e mail is augusto_bassan@yahoo.com.br
augusto_bassan is offline   Reply With Quote
Old   August 22, 2009, 13:39
Shefali
shefali is on a distinguished road
Hello Nic
The correlation which you are using is for the case when fluid is attached (or in direct contact) with (long) flat plate. However as far as I understood your problem the correlation shall give you overestimate of the heat transfer. The fluid which is flowing shall create a recirulation in the cavity and the Nu relationship shall notconvey the physics. I will suggest you to look at the literature on OPEN LID CAVITY PROBLEM.
shefali is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
