Subsonic heat trasfer test case
Old   November 12, 2003, 13:01
Default Subsonic heat trasfer test case
senthil
Hi All Iam looking for a subsonic test case with heat transfer for validating my code. Can anyone suggest some. Thankx and regards Senthil
Old   November 13, 2003, 04:30
Default Re: Subsonic heat trasfer test case
jdc
Hi Senthil,
I am not sure whether your code provide turbulence modeling. In such case, a CFX report (see http://www-waterloo.ansys.com/cfx/horizons/sst.htm ) may provide you several test-cases as well as their code performance.
Have fun, Julien
Old   November 13, 2003, 06:54
senthil
Julien Thankx for the information. Sorry that i did'nt make it clear. Iam looking for compressible flow cases. Mine is an fully compressible,unstructured,k-e code. Thanks and regards senthil
Old   November 18, 2003, 09:08
Li Yang
As long as you use preconditioning, compressible solver should be also OK for low speed air flow simulation.
heat trasfer hittie FLUENT 0 March 11, 2011 13:29
ONERA C1 test case CFD Student Main CFD Forum 0 June 30, 2007 07:31
Porous Media test case Alex FLUENT 0 April 9, 2006 08:23
Heat transfer: test case Pawel FLUENT 0 October 24, 2001 09:16
Heat Transfer Validation test case Chris Whitney Main CFD Forum 1 July 21, 1999 14:36
