Small Y+
Old   September 18, 2009, 10:26
Default Small Y+
Shannon Galway
sgalway is on a distinguished road
Is there a disadvantage to a small Y+? I know for shear stress transport models I am looking for a Y+ less than approximately 2. Is there a disadvantage/error to having this number much smaller than that (like 0.2 for example)?
sgalway is offline   Reply With Quote
Old   September 25, 2009, 09:08
federico
aatman is on a distinguished road
Are you simulating a wall-bounded turbulent flow? if you use DNS or LES your first computational node off the wall must be at y1+ = 1 or even y1+=0.5, but this mean a very large ammount of nodes. With wall function (this means that you are not making DNS anymore) you can put your first node in the log zone, so y1+ > 30, and you can save the number of computational nodes.
aatman is offline   Reply With Quote
Old   September 25, 2009, 13:43
kumar
cfd_lean is on a distinguished road
Hi For wall integration grids we need to have y plus around 0.2 to 1. where as with the low y plus values you will see some convergence issues. With the low y plus values there is possibility to predict wrong gradients. That will screw up your complete solution.
cfd_lean is offline   Reply With Quote
Old   September 25, 2009, 22:23
Shannon Galway
I am modeling the leg of an offshore jackup drilling rig. Therefore, this is an open flow around an obstruction.
Can you expand on the "convergence issues". Why would low Y+ values give convergence problems?
Thanks for all the help. I really appreciate it.
why did Time step is too small in stiffbs? satum FLUENT 1 December 10, 2012 09:15
Do small boats slow big boats? Richard Scott Main CFD Forum 13 August 3, 2004 03:51
SGS small scales == fluctuant scales ?? Bin Li Main CFD Forum 6 February 26, 2004 12:35
what happens if y+ is too large or too small Bo Jensen Siemens 12 February 19, 2003 23:31
small size holes simulation brian ko Phoenics 5 October 22, 2001 12:53
