Prism layer advice needed for steady state port flow case
Old   September 24, 2009, 12:14
Default Prism layer advice needed for steady state port flow case
Digital_Junkie
MaxCFM is on a distinguished road
Please share your insight on how to properly design prism layer strategy for steady state port flow case. Inlet/Outlet pressure differential is 6975 Pa. I'm using a realizable k-e turbulence model. The geometry is a 4-valve per cylinder (2 intake / 2 exhaust) intake port. The geometry is symmetrical so I am only modeling one half of the geometry. Intake valve OD is 37 mm. valve lift is 14 mm.
My questions are:
  1. How can I determine desirable thickness of prism layer? Should thickness be a Percentage or Absolute?
  2. How many layers should there be?
  3. How should they be scaled/stretched?
  4. How can I determine what my Y+ values should be?
Any advice you can offer would be greatly appreciated. Thank you
MaxCFM is offline   Reply With Quote
Old   October 1, 2009, 09:26
Digital_Junkie
Somebody throw me a bone!
Boundary layer strategy for port flow case? MaxCFM Main CFD Forum 1 September 9, 2009 06:09
Advice on multi-phase flow modelling Martin Main CFD Forum 3 October 14, 2008 05:16
Boundary Layer Flow Paradox Wen Long Main CFD Forum 3 September 24, 2002 08:47
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
