not convergence in high angle of attack in low reynold number
Old   October 1, 2009, 01:14
Default not convergence in high angle of attack in low reynold number
labib
nuimlabib is on a distinguished road
why at the angle of attack iof airfoil s increased in the range of 10 degrees, iteration does not converge, but at a low angle of attack 0 to 8 degrees, to achieve convergence, I use the segregated solver, implicit, and K-W turbulence models, why can not achieve convergence. where lies the fault .. I put the inlet velocity boundary conditions of 2.5m / s, and the chord length 1m. help me..
nuimlabib is offline   Reply With Quote
Old   October 2, 2009, 14:10
Josh
jstults is on a distinguished road
Take a look at your residuals, you will probably notice that they are large and unsteady on the upper aft portion of your airfoil, and you'll probably have some unsteady shedding behaviour as well that will cause high residuals in the wake.
At high angles of attack, there isn't really a physically meaningful 'steady-state' for you to converge to, the physically meaningful solution is unsteady.
jstults is offline   Reply With Quote
Transient Angle of Attack Simulation Not Displaying in Post Josh CFX 35 August 5, 2009 09:16
low and high Reynlods numbers amar FLUENT 1 July 23, 2009 11:51
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
Low Reynolds number K-Omega modeling Athar Zaidi Main CFD Forum 0 October 31, 1999 13:59
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 13:46
