Reinolds number in sola-vof.
Old   October 21, 2009, 02:47
Question Reinolds number in sola-vof.
JSS
Jas
JSS is on a distinguished road
hello, friends!
sorry for stupid question.
Please, help! How I can define Reinolds in program (for example sola-vof)? for simulating some process with others Re.
Please explain the issue with the dimensions. How to set the dimension of the variables in the program?
thank you!
JSS is offline   Reply With Quote
Old   October 21, 2009, 10:12
otd
private
otd is on a distinguished road
Most of the Los Alamos codes written at the time of Sola-Vof (~ 1980) allow any consistent set of units to be used. There are no units specified for the examples in the LANL report documenting the original code.
That is, the body forces g_x and g_y, the velocities (u and v), the viscosity, the density rho, the surface tension (for free surface simulation) and the mesh units (x, dx, y, dy, etc) must all be consistent. You can use cgs, MKS, English units (pounds_m, feet, seconds), etc. Or non-dimensionalize the equations, which will form dimensionless quantities (Reynolds number, etc). You should find help in engineering texts for heat transfer or fluid dynamics - subtitles might be "dimensional analysis" or "Buckingham's Pi Theorem."
This should all be worked out before you start inputting to the code.
otd is offline   Reply With Quote
Old   October 21, 2009, 13:15
JSS
Jas
Thank you!
One last question: how can define сircle on grid in VOF method?
I tried to manually fill the fluid cell, but I could't configure cells at the boundary of the circle. And I think, that my "method" is wrong.
May be by some equation possible to specify a this configuration for F?
Old   October 21, 2009, 14:17
otd
private
Sorry but I don't really have much experience with the VOF option. Only things I've used it for are simple surfaces that initially coencide with cell boundaries.
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
