October 21, 2017, 07:36 |
CFD Mass exchange across a reactive front
Peter Pan
I have a CFD solver at hand which can deal with 2 phases and so far is able to exchange momentum and energy across the interface, where both phases meet. How this is done is well documented in the following paper "A conservative interface method for compressible flows" by Hu, Khoo and Adams, which publicly available.
In the paper, equation (10) is giving the general idea of how to update the conservative variables in so called "cut-cells", cell's which are cut by the interface (tracked by a level-set method). In this update routine holds the average energy and momentum exchange. Now I want to extend the code such that it can deal with reactive fronts (like combustion or cavitation). The arising Riemann problem is now solved by a reactive Riemann solver, which provides next to pressure and velocity across the contact discontinuity, also the mass flow through the reactive front. So far all good, but now I am having troubles to adjust such that it transports the mass (density) across the front. I would be very grateful for any thoughts or hints. Thanks in advance! Paul |
massexchange, reacting flow, reactivefronts |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 11:46 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 12:23 |
